Old 19-Mar-2010, 2:38 PM   #2
Tuner/DVR
Go to http://www.channelmasterstore.com/ channelmaster has a new Broadcast Television Digital ATSC Tuner/DVR the CM7000PAL DVR (CM7000PAL) has a built in hard drive. The outputs of the CM7000PAL will work with any Tv. If you will like to record on to DVD's then check out the Panasonic VIERA DMR-EZ48VK it has a Broadcast Television Digital ATSC Tuner , records on to DVD's and has outputs that will work with any Tv. And if you will like to up grade , the DMR-EZ48VK is made to work seamlessly with some VIERA Panasonic Tv's using one remote to control every thing. http://www.panasonic.com/
Last edited by teleview; 3-Apr-2010 at 7:09 PM. Reason: Add more information and make more understandable
