Old 24-May-2011, 8:47 PM   #10
HannahWCU
Originally Posted by John Candle View Post
The stations at your location are strong. So a 4 bay should work. The other reason we are suggesting using 4 bays is - Beam Width. Beam width is the degree of a angle from the center of the reception at the front of the antenna that the reception will be reduced to half power strength. . 4 bays have a wider beam width and 8 bays have a narrower beam width. The stations you will like to receive are at wide spacing of angles / beam width.
That is good to know. Thanks!!
HannahWCU is offline   Reply With Quote
