TV Antennas and Reception
The stations at your location are strong. So a 4 bay should work. The other reason we are suggesting using 4 bays is - Beam Width. Beam width is the degree of a angle ( to the right or left side ) from the center of the reception at the front of the antenna that the reception will be reduced to half power strength. . 4 bays have a wider beam width and 8 bays have a narrower beam width. The stations you will like to receive are at wide spacing of angles / beam width.
