Antenna Type
Looking at the >>Start MAPS<< part of the tvfool web site. I see transmitters all around your location both on the Canada side and USA side all of these stations are close and are receivable so it depends. You have several choices here. You could try an outside rooftop omnidirectional antenna , sometimes called a UFO antenna because it looks like a UFO. Or if were to choose a directional antenna you can choose what stations you will leave the antenna pointed at. You could install 2 rooftop directional antennas with 2 separate antenna mounts and 2 separate antenna rotors. I would try a UFO omnidirectional antenna , you can get one at Radio Shack , if it does not work out that well for the Tv stations you will like to receive , you can take it back.
