Stacker or not.
I present the facts. Here is a helpful hint. The RG 6 coax that is connected between power supply and the preamplifier should have a solid copper center wire , not copper covered steel. The reason is the solid copper has less resistance to a preamplifier power supply voltage and current. The copper covered steel has more resistance. This does make a difference and I can present links to the information. Or you can look it up your self on the internet.
