Tv Antennas and Reception
Here is some thing you can try , with and with out the UHF reflector. Rotate the antenna you have around so that it points at about 51 degrees magnetic compass , WQPX and WSMB. This will increase the reception of those two channels. The other stations are very strong so the stations will still be plenty strong.
