Old 20-May-2011, 10:04 PM   #2
Tower Guy
Originally Posted by sofakng View Post
Would a pre-amp or booster help with these problems?
Nope, the problem isn't signal level, but signal quality. The solutions are:
A rotator that will turn the antenna when you want to watch WQPX or WSWB.
A second UHF only antenna aimed at WQPX and WSWB with an A/B switch.
A second UHF only antenna aimed at WQPX and WSWB with a custom frequency selective combiner. The manufacturer would have to tune the single channel input to 12 MHz wide to allow both channels 31 and 32 to get through the fiter.
Tinlee AC7-Series
Single Channel Injectors, join a single channel antenna with a broadband antenna or separate one channel from a broadband antenna. This three port device consists of:
1. Single channel input (bandpass) which provides 20dB rejection at: ±8 MHz (VHF), ±18 MHz (UHF). Insertion loss: 2 dB typical
2. Broadband input (bandstop) which reduces signal overlap between the single channel input and the broadband input. Rejection: 15dB. 3dB points: ±8 MHz (VHF), ±18 MHz (UHF)
3. Thru-port (common). Passband: 40 to 860 MHz, thru-loss: 1dB
http://www.tinlee.com/MATV_headend.php
