Old 20-May-2011, 6:48 PM   #11
gduke
Thanks TG.
I see the line between the transmitters and the OP's location passes just north of Jackson Evers Intl Airport and through downtown Jackson MS. Both are prime sources for multipath.
This symptom is consistent with aircraft operations at an airport with scheduled operations.
The best advice I've got for now is, try the antenna outside the attic. You have control over that known source of attenuation and signal reflection.
I'm going to try an attenuator and if that doesn't work then I'm moving it outside.
gduke is offline   Reply With Quote
