Thanks TG.
I see the line between the transmitters and the OP's location passes just north of Jackson Evers Intl Airport and through downtown Jackson MS. Both are prime sources for multipath.
The picture will stutter/pixilate/drop sound for a split second every few minutes.
This symptom is consistent with aircraft operations at an airport with scheduled operations.
The best advice I've got for now is, try the antenna outside the attic. You have control over that known source of attenuation and signal reflection.
