Thread: can't get abc
Old 20-May-2011, 4:26 PM   #5
Tower Guy
Originally Posted by wwfry View Post
i get all the channels listed in green except for the abc channel: whtm-dt.
it seems like if i would get whp-tv, then i would get this as well.
WHP is on UHF, WHTM is on VHF. WHP is 9 db stronger than WHTM. The Philips antenna does better on UHF than VHF. You can't use an amplified antenna, WPMT is too strong.
The best solution is a roof antenna. If you want to continue playing with an indoor antenna, consider the Terk HDTVi, but be prepared for hours of adjusting, scanning and tweaking.
