Tv Antennas and Reception
Talking about a VHF high band tv transmission that is 27.5 NM(dB) that is a good mid range signal strength as a example. Is a lot different then WYIN-DT UHF 17 at 12.3 NM(dB) , a Low signal strength. For combination VHF-UHF-FM antennas it is a good idea to error on the side of more antenna. And this information also holds true for VHF only antennas , UHF only antennas , FM only antennas. . Antennas are to be selected for the lowest signal strength of the channels to be received.
