Old 19-May-2011, 2:31 AM   #1
Bureaucromancer
Antenna Choice (Toronto)
http://www.tvfool.com/?option=com_wr...5747cbfba6c982
Currently I'm using an indoor set top antenna (silver sensor clone) with pretty decent results for local stations. Mostly I'm trying to get PBS reliably (its intermittent as is) and the American networks if I can without screwing up local channels.
Basically my only real outdoor option is a wall mounting on the second floor, south facing (I could also do west facing, but its a straight shot into the neighbours house across the driveway and doesn't help directionally). I've been looking at the DB8 or Channel Master 4228HD, am I on the right track? Other suggestions? Preference between the two (from what I've seen so far I've been somewhat leaning toward the DB8 as more multidirectional, but since I can get local stuff with a coat rack it doesn't REALLY matter much...).
Bureaucromancer is offline   Reply With Quote
