When signal strengths are in the moderate to weak range it is better to select more antenna. Cutting it real close to the border line to save a few bucks is not a good idea. . With a smaller antenna you will find your self saying . If had the better antenna I could have added one more tv to the hook up with out using an amplifier. Now I will have to spend more money for a amplifier then having the better antenna in the first place.
