Thread: Culture Wars
Old 18-May-2011, 7:30 PM   #15
The UHF antenna you referred to is a good choice. The CS5 is a good choice to cover the high-VHF. The combination of those two antennas correctly installed on the roof should be able to deliver all the stations on your report down to the bottom of the yellow section -- in the direction aimed provided co-channel or adjacent channel interference is not present.
I would be looking into tripods, gable and chimney mounts.
