Old 18-May-2011, 2:43 PM   #4
Tower Guy
Originally Posted by John Candle View Post
It is a all channel antenna and will receive KCSO-LD 3 , KCSO is showing the digital channels to be 3-1 Telemundo and 3-2 ME TV
My experience with low band reception is that TVfool should be taken with a grain of salt. The NM value calculated by TVfool does not add the low band noise penalty. The FCC uses 4 db, but channel 3 is probably more like 8 db. The secret to low band reception on channels 2&3 is a quiet location, plenty of antenna height, and as much gain as possible. My selection for extreme low band reception include the HD7084P, CM 3671B, and HD5030. The HD5030 would also need a UHF antenna for the remaining stations.
Because of the budget restraints, I would not even try for reception of channel 3.
