Thread: Culture Wars
Old 17-May-2011, 11:06 PM   #9
John Candle
Tv Antennas and Reception
I recommend pointing the the UHF antenna at about 120 degree magnetic compass and adj. for best reception of the UHF stations at 88 and 153 degree magnetic compass. I recommend pointing the C5 at about 141 degree magnetic compass for best reception of the VHF High channels. Use the UVSJ = UHF-VHF-Separator-Joiner to connect the two antennas. Remove all preamplifiers , amplifiers , splitters and etc. and connect direct to one 1 tv. Due a channel search scan with the Tv with no antenna connected, this should clear most of the channels out of the tuner so the Tv can start fresh with a new scan when the antenna is connected.
