'How are you combining the two antennas?' is an excellent question. A UVSJ would be the better choice over a reversed two-way splitter. Fluctuating signal strength indication on CH-14 suggests multipath which can change with the season, the weather and construction of buildings near and far. Multipath symptoms can also be caused by damaged coax, connectors and poor combining technique.
All amplifier components (power supply and antenna unit) are completely removed, disconnected, yes?
KLSR 'should' be not be difficult to receive. In fact, you should easily see stations down into the yellow section of your report. The attic construction may be attenuating and/or reflecting signals far more than you realize. You say you have tried the antenna outside, which antenna, how high and what aim point(s)?
