Thread: Culture Wars
Old 17-May-2011, 3:54 PM   #4
dkreichen1968
For the PBS problem, I'd call the station. It sounds like digital artifacts from over compressing the signal on their end. Did they add channels, or otherwise modify the signal recently?
For the FOX problem, it sounds like multi-path. Has anything changed in your neighborhood or in your house? (New Construction, moved appliances, etc.) Did you have any of these problems before adding the C5? Did you use a UVSJ (UHF, VHF, Splitter, Joiner) to connect the C5 to the UHF antenna? If not, that may be your problem.
dkreichen1968 is offline   Reply With Quote
