Old 17-May-2011, 2:17 AM   #4
Antenna selection is based on the real channel, not the virtual or display channel number. There are no low VHF transmitters indicated on your TV Fool report.
With the exception of WHAS, real channel 11, the Louisville stations are receivable with a large UHF antenna such as the Antennas Direct XG91 or Winegard HD9095P. Reception of WHAS would require a high band VHF such as the Winegard YA-1713 or Antennacraft Y10713. A dual input preamp such as the Antennacraft 10G221 would combine the signals from the two antennas into a common coax down-lead.
Unless you are able to consider a tower in excess of 100 feet high, reception of Indianapolis stations is not possible. For example, WRTV (ABC) is a tropospheric path with adjacent and co-channel interference and the predicted signal strength at 30' AGL is at least 15 dB lower than capability of the largest consumer grade antennas.
