Old 16-Dec-2009, 6:12 PM   #3
rabeatz
I did pick up a little indoor amplified antenna by RCA, picks up a couple channels like the WESH, but there is alot of stuff on the desk I put it on, and tuning it (digitally) is a challenge since you don't get the snow to tell you if it's better or not.
The current antenna actually has two antennas mounted on the pole - the lower one looks similar to this:
http://freetoronto.tv/images/AntV1ch.jpg
While the one on top that I was connecting to looks similar to this:
http://www.rocketroberts.com/cm4251/..._ant_jan83.jpg (bottom antenna in image)
With it being 30 years old and breaking, i figure it needs to be replaced anyways.
Do you know what CEA color code the two antennas you mentioned are in? I will probably look those ones up later, but I'm on a budget and trying to stick to $30-$50 dollars for the antenna.
I was going to get the Antennacraft® HBU22 High-VHF/UHF Antenna until I looked up what Blue/Violet are and realized it was nothing close to what AntennaWeb said I needed.
Are far as splitting the signal - it would probably go to 3 different TVs. Would it be more effective to add a pre-amp or other forms of amplification, or to get a larger antenna?
Another thing - when Dishnetwork connects their satellite dishes, do they run anything in the coaxial line that would interfere with the antenna signal? Conveniently, my Dish was installed directly next to the antenna, so I can just disconnect that and connect it to the RG-6 that dish installed.. but I guess I need to go into the attic and see if Dish put anything on that line that would mess with the signal, or if it runs stright to the Dish receiver.
rabeatz is offline   Reply With Quote
