Old 16-May-2011, 2:06 AM   #3
kenuks
Yes I checked and the antenna is rotating as it should.
I can get on the roof next weekend and check connections.
It just seems very strange that this happened while I was adjustng the Channel Master today. I could see the signal changing on the TV I was working on throygh the TV menu.
I belive the problem may have started when I pressed the sync button the Channel Master. The other TV lost the channels and there was no more fluctuations on the signal rate at the TV I was working on.
I checked further and I have a third TV that gets the same channels,
kenuks is offline   Reply With Quote
