Old 15-May-2011, 11:58 PM   #2
Have you verified that the antenna is actually rotating when the control indicates? How difficult will it be for you to check for damage to the coax and connection integrity at the antenna / rotator?
Kinked, pinched, cut, loose, broken or corroded are all undesirable adjectives when describing antenna system components.
