Old 15-May-2011, 6:29 PM   #6
brad5675
Originally Posted by John Candle View Post
It would be better to use a http://www.slingbox.com . The sling box is set up where the channels are easy to receive ( close to the transmitter ) and the sling box receives the channel and transmits the channel ~via~ the internet to your Tv.
I have gone to the Slingbox website but had no luck finding the information I need. What kind of range does the slingbox have? Do you think the Slingbox will be able to improve reception enough to pull in channels from the grey area? You mentioned "channels easy to receive (close to the transmitter), please explain. Thanks for your patience in this.
brad5675 is offline   Reply With Quote
