Quick update guys, climbed the tower after work, raised MANT 5' feet higher, pointed at about 330 degrees in the horizontal position (does this matter, vertical or horizontal). Every channel I want comes in (6:30pm) Except, as stated above WYTV and WOIO. They try to come in but with digital breakup, they do come in later at night though, pretty good. FOX cleveland has a digital breakup every 5 min or so, the smallest amount if any. Everything I just said has pretty much always been the case for the most part, just wanted 100% reliable. Would adding a preamp to the MANT work? I cant believe it picks up youngstown though when thinking about it (pointed 330degrees). So could I add a preamp, keep in mind it has to have the 18db inline hooked up to it.
Thanks
