There are two versions of the Terk, one amplified the other not. The photo on Amazons website is of some Philips product, quite confusing. Another inexpensive option is the RCA ANT-111.
I don't envy your predicament. My best suggestion would be to try one of the simple non-amplified antennas. If you can purchase from a retailer with a friendly return policy, all the better.
If you can't get satisfactory results indoors, then I think you have proven sufficiently that your building construction is a problem for reception. An outdoor antenna would be the next option to consider. The RCA ANT-751 is a fairly small outdoor antenna that can be wall mounted... a big plus over the larger roof top options.
