Your TVF report title indicates an antenna elevation of 0'. I suspect that at roof top level, conditions will be a bit better. Reasonable effort to take advantage of the available elevation should offer improved signal quality.
Given dense mature trees close in, you will need to err toward the larger antennas. If WMUR is the 'must-have' that it sounds like, consider using a Y10713 instead of the Y5713. The XG91 is the 'big-gun' UHF antenna already.
