Old 12-May-2011, 6:47 AM   #6
The RCA ANT-751 will do a fairly good job for you. It is not ideal if you want to reliably receive real channels 2 through 6. I suspect that real channel 4 (WPXO) will be OK due to the signal strength available, but real channels 2,3 and 6 further down the list may not be reliable.
I expect that most of the other stations in green and yellow on your TVFR will be received by the ANT-751.
