Yes the spread from KCPQ-DT 13 and KWDK-DT 42 is very wide. The best way to find out for reception is set up an indoor antenna and see what you can get. . . Or if you will like to put a antenna outside then I suggest a Channel Master CM 3010 without the optional amplifier , and a FC-300LX flat coax for the patio door. . For the most part there is no perfect solution for apartment reception.
