Are you disconnecting and discontinuing direct tv service?? . Most all question askers are getting rid of pay satellite and pay cable because of the high cost and going to a Tv Antenna. . If you are keeping satellite and also adding antenna then the wiring will need to be done differently. There will be 2 separate wiring systems. Need to be clear here , You say you are keeping the 4 Tv's on satellite and not adding a Tv antenna to them but you will have 2 extra Tv's on Tv antenna and not satellite???? Which end is up????
