Old 5-May-2011, 10:45 PM   #16
I would not have recommended an amplified antenna to begin with. The HD7694P will not need an amplifier. If installed outdoors, in the clear, it should provide sufficient signal power to drive an 8-way split.
An attic is an unpredictable and variable environment. If you are able to get acceptable reception with your antenna protected in the attic, great, you will get nearly unlimited life from your antenna. If reception fails during wet weather, you'll need to decide if that is preferable over moving the installation outdoors.
