Old 5-May-2011, 3:44 PM   #10
Tower Guy
Originally Posted by misterpants View Post
Do you have any thoughts on why this would be a problem on only one station (Fox) while other similar stations (ABC, NBC, and CBS) with almost identical signal strength, distance, and direction are all coming through flawlessly?
That's the right question.
One possibility is that channels 30 and 32 form a 3rd order intermodulation product that extends from channels 34 through channel 35. In addition, channels 29 and 32 create an IM product that falls on channels 35 & 36. KDFW is on channel 35. The complete technical explanation is here: http://www.tvtechnology.com/article/73532
If that's correct, the solution would be a non-amplified antenna.
