Old 17-Mar-2010, 1:20 PM   #10
Tower Guy
Originally Posted by rwilson1206 View Post
Are two antennas really necessary?
I would like the option of something side mounted to be a possibility, just it case I cant install it at the top.
I have a phillips 18db signal amplifier now, if I had to throw that in the setup somewhere, and another 18db inline that the phillips antenna came with, although I dont know if its esp for that antenna, I think it is.
Two antennas or a rotor, your choice.
The 4221 can be side mounted, but it won't pick up WJW or WOIO. The only VHF antenna designed to be side mounted is the Antennas Direct C5. If you opt for the C5, you'll need three antennas.
Amplifiers are fickle. A good amp can help pick up a weak station, but two amplifiers or the wrong selection, and you loose the advantage.
