Old 5-May-2011, 6:36 AM   #29
Yaguy
RE: Antenna options
Thanks No Static at all and GroundUrMast
How weak a powered signal can say a combo antenna like an RS VU-160XR be able to pick up without a preamp? Right now, I'm having difficulty with stations below -41 to -45dB. I'm running about 50' of coax to the grounding block outside, another 10' to the 2-way splitter inside, then 15' to the basement TV, and about 25' to the upstairs one. Total: 100'
Can the 300 Ohm to 75 Ohm balun on the antenna go bad over time? It's the stock one that came with the Antennacraft antenna. Age: 20 years.
I'm trying to sleuth my way through it all.
Yaguy is offline   Reply With Quote
