Reading the web some more, getting some more education before spending more money on antennas. Using the Google Earth data and found that I had the antenna pointed about 10 degrees off from where it should be. Redirected the antenna and found that for the UHF channels the signal strength went up 50% or more as indicated on my plasmas signal strength indicator. The high VHF channels had insignificant increases and with the rains I get dropouts on 7 & 12.
I can locally pick up a HD7694 for about the same as a shipped YA-1713. Do you think the HD7694 by itself will be enough?
