Old 4-May-2011, 11:17 PM   #25
K24IC is a translator for KBTC a PBS affiliate. They carry three virtual channels , PBS in HD, MHz, and TVW a State government information channel.
A 4-bay panel should have no trouble with the three US stations 47 miles south of you. An 8-bay will offer gain you don't need and a narrow forward beam, which is also going to work against you. You might get lucky with a 4-bay and find a compromise aim point that lets you watch all channels but I won't be surprised if you need a rotator or a two antenna system.
The RS VU-160 should have been quite capable also. It sounds like it has problems though. The attached file indicates UHF gain similar to what you would expect from a 4-bay panel.
I see KVOS has started to carry 'ME' network programing instead of local production and locally selected syndicated oldies.
