Old 4-May-2011, 4:55 PM   #27
Originally Posted by Billiam View Post
GUM. Thank you for taking the time to do these calculations. That spacing distance is considerably better than the 38 inch option.
Won't those elements be awful close together on the back of the antenna?
I assume this distance will work for any antenna that receives CH. 7 and not just the YA 1713?
Your math is correct. I did extrapolate off the right side of the graph. In any event you may have discovered an offset in the HDTV primer graph.
Unfortunately the element length of the reflector is longer than 31 1/8".
Yes, that's a problem. One option is to use 3/2 wave length on the vector toward KOAM which would make the parallel boom spacing 93 3/8". (Do I hear an 'OUCH'?)
