Old 4-May-2011, 6:52 AM   #24
I'd suggest that the problem is a combination of a weak signal and interference from KOAM.
Your pair of Y1713s can be stacked horizontally about 34" apart to null KOAM and still add 2-3 db to KQTV. http://www.hdtvprimer.com/ANTENNAS/ganging.html
When combined with a CC7870 they will add by about 2 db. If this arrangement works your problem is interference. If not, you'll need more antenna gain.
When I crunch the numbers, I come up with 31 1/8" boom to parallel boom to null KOAM. Logarithmic center frequency of CH-7 = 176.975 MHz so 1/2 wave length = 33.34618". Relative angle of KOAM vs KQTV = 111°... 33.34618" * COS(111-90) = about 31 1/8". If you are building a Horizontal stack, just be sure you can adjust the boom to boom dimension a bit either way.
If you want to field build a balanced open wire line combining harness, here is a table for various wire gauges.
File Type: pdf Air Insulated Open Wire Balanced Line.pdf (5.4 KB, 1165 views)
