This antenna seems to have a few devout fans (as in fanatics)... Because I can't locate any information other than anecdotal reports and testimonials, I don't know what the real gain of the HD Stacker is. I won't recommend the HD Stacker to you or anyone else, because there are many other antennas available that have published specifications which are recognized as trustworthy.
I hope you can get your money back if it lets you down.
Re. grounding: Use the ground lug on the splitter if the antenna is located in the attic.
