Old 3-May-2011, 5:15 PM   #18
Originally Posted by hanknum View Post
...Right now I just have indoor antenna (Philips SDV2210/17) and using an Access HD digital to analog converter...
How has that been working for you? Can you list the channels that are reliably received? Are there channels that you are having trouble with?
It would helpful if you could refer to the real channel rather than virtual channel numbers.
Because you have two sets, I would think you would find a rotator inconvenient for the viewer who does not have control of the antenna direction. There is a chance you may get acceptable reception from the rear of the outdoor antenna... if so, you will not need a rotator or second antenna.
