Old 3-May-2011, 3:33 PM   #5
John Candle
TV Antennas and Reception
If you will like to reach out for the American Stations then I recommend a Winegard HD7698P antenna , http://www.techdepotcanada.com with a Channel Master rotor CM 9521A , http://www.saveandreplay.com , http://www.trentondistributors.com . If the antenna is connected to one tv then a rotor works well , if the antenna and rotor are connected to more then one tv then disagreements will happen about what tv stations the antenna is pointed at.
