TV Antennas and Reception
The antenna is a all channel Vhf/UHF/FM antenna. This is a good antenna to have. Check all outside coax connections for corroded contacts and bad matching transformer. I recommend replacing outside coax and All outside connections and matching transformer with All New. The best direction to point the antenna is 311 degree magnetic compass. If the antenna is pointed into the roof at 311 magnetic compass then the antenna height will need to be raised up higher. If the antenna is barley clearing the roof then the antenna will need to be raised up higher. Here is how to point tv antennas , http://www.kyes.com/antenna/pointing/pointing.html
