Where are you located ? have you tried to contact Denny, maybe he could point out a few tricks to help you out. His support is top noch.
You wrote that you didnt try the uhf section so you didnt place the twin lead ? you should try that out, thats what makes this antenna perform, the two antennas help each other out.
Have you tried 91xg's ? that one of the most powerfull uhf yagi antennas out there. im sure with this you would get your channel 7. Do you have a two story house ? if not i would try a push up mast from channel master, id get a 30 foot one.
