Thread: Antenna help
Old 2-May-2011, 4:42 AM   #1
Keypad
Antenna help
http://www.tvfool.com/?option=com_wr...8d17630c555715
I live out in the country, in a wooded area. Cable not an option for me. The house has an external antenna that's 10 yrs old on a mass attached to the roof (guessing 40 ft for the hieght). The antenna is a flat arrow type, small fines leads the point towards the towers. I have a new tv so convert box isn't needed. The problem is weak signal from locate station that are with in 50 miles. I'm think of replacing the antenna with Antennacraft hbu33 or better. Never rely had a problem until after the switch from analog to digital. Would appreciate any help or suggestion, thank you.
Keypad is offline   Reply With Quote
