Old 1-May-2011, 9:08 PM   #11
Tower Guy
Originally Posted by Billiam View Post
Where do I measure the 34" distance from on each antenna? The balun? Or elsewhere?
Also, what do I use for a horizontal boom?
If it were me I'd use a standard TV mast cut down. I've used standard TV mast for a pair of low band antennas.
I'd redrill the booms 90 degrees from the existing holes and slightly offset one way or the other. It's best if the horizontal boom is halfway between two elements. Next I'd drill two holes on the the horizontal TV mast to mount it on the vertical mast.
