Thinking out loud...
Are the YA1713's stacked one on top of the other? (Or side by side?)
KOAM and KHQA are both strong enough co-channel interference sources to present a problem. Side by side stacking can produce a more narrow horizontal beam-width which would be desirable, as a means of rejecting the interfering signals.
Use of a reversed splitter (CC7870) as a combiner comes at the cost of about 3 dB. You still get the modified beam-width though. A pair of Antennacraft Y10713 with their 300 ohm outputs would lend themselves to combining via 1/4 (or 3/4) wave long sections of 450 ohm ladder line, thus less combining loss.
I think your consideration of the combo antennas is a viable option also. But you'll need to find an antenna with at least 3 or more dB additional gain to expect much difference.
I think the solution is going to be a combination of gain and interference rejection.
