Old 1-May-2011, 5:08 PM   #7
TV Antennas and Reception
If good reception does not happen with the HD7000R of the Tv stations at 56 and 293 magnetic compass , then a second antenna will need to be added. I suggest a Antennas Direct - ClearStream 2 UHF antenna - pointed at 293 magnetic compass. Separate RG6 coax will be connected to each antenna and the separate coaxes will be brought to the location of the Tv and connected to a remote control A/B antenna switch , Model number ab27rs or 15-1968. The output of the A/B switch is connected to the Tv.
