Old 29-Apr-2011, 12:23 AM   #7
Originally Posted by No static at all View Post
There is some pretty strong FM around you as well that the 7694 may be seeing more of than the Lava did. I would try an FM trap as well.
I ran the FMfool report for the correct coordinates. The strongest FM signal is WLZL which is 2 edge and -35.4 dbm. The TV set with no preamp and any HD769X antenna should handle that fine. By comparison WBAL is -51.5 dbm.
