Old 16-Mar-2010, 2:33 AM   #6
mtownsend
Originally Posted by Gus View Post
ABC (22.1) I only see my TV showing a signal (diagnostic menu in the TV), but I get a black screen. Is my TV too "old" to decode this signal? Is like there is a carrier wave but no info...(?!)
No, there should not be any problem with signal decoding. Any receiver capable of decoding ATSC signals should be able to show something as long as it has a good signal to work with. The ATSC broadcast standards have not evolved to the point yet where there are incompatible legacy receivers.
Your problem is most likely a simple matter of not having a good enough signal to work with. If the receiver cannot lock on to the ATSC signal properly, it cannot decode the stream of digital data, and it won't have any picture to display.
This may mean that you need a better antenna setup to get this channel.
To better understand your signal situation, it would help if you could post a signal analysis report for your exact location. For help on how to do this, there's a brief guide to using the tool available here: http://forum.tvfool.com/showpost.php?p=3
