Old 27-Apr-2011, 6:24 PM   #2
The attic is an unknown in terms of attenuation. So rather than suggesting an antenna that will be marginal if everything is in your favor, I'd recommend the Antennacraft HBU-33. If you continue to have difficulty with reception from within the attic, it can be folded back down and mounted outside were it will be plenty of antenna.
Aim toward the SE.
