The 7694 is more than enough antenna. Is there a metal cap on the chimney or anywhere within a foot of the antenna?
There is some pretty strong FM around you as well that the 7694 may be seeing more of than the Lava did. I would try an FM trap as well.
I've put up 3 7694's in Northern VA with weaker strengths than yours & results have been quite satisfactory. 2 of the locations are spotty at times with 11 & 13, but good for the most part.
Are you seeing WUTB-24?
